4.3L Part out Plus Trans and tuning stuff
SchnellGhostTy
ALL SOLD
Here it is!
Almost new, everything has less then 2500 miles on it! Every Sensor and Bolt Was Replaced!
I snapped the crankshaft and have decided to put an LS in it instead of rebuilding a 4.3 again so everything 4.3L related must go.
I want to try and sell in groups of particular systems per say since things are engineered specifically around the parts assembled.
The rotating assembly still needs to be inspected as of 1/1/14
*JE Forged Aluminum Pistons 8.5:1 $
*Eagle H Beam Forged Rods $
*Stock Typhoon Engine Block .030 Over 2 Bolt Mains
ARP Head Studs and Bolt Mains $
*Comp 412 Camshaft $
*Deepened Oil Pan and Welded AN Oil return Line Fitting $SOLD
TURBO KIT
*GTX3582R Garrett Dual Ball Bearing Turbo W/ Billet turbine Wheel
(It whistles like a supercharger at idle) $
*Full Boost at 2500RPM
*AN Lines - Coolant Feed and Return and Oil Return - stock oil feedline $
*T3 Turbo Manifold Spacer w/ external 38MM Wastegate $
*Tial 38mm Wastegate Blue $
*Custom Stainless Steel Dump in front of the Passenger Well $
*4" Intake 90* with PCV System AN Connection $
*AFE Cone Filter $
*Custom Aluminum Turbo to Intercooler Pipe with Tial 40MM Blow Off Valve & Wastegate Boost Pressure AN Fitting $
*3" Down Pipe, 2 Vband Clamps and a sleeve at the end to match the rest of the exhaust $
*PCV System - AN lines to Moroso Oil Separator and then to intake w/ 3 factory check valves, two on pass and one on driver side $
*Complete Vacuum line setup(As its supposed to be! in complete AN Fittings and un-collapsible Silicone Lines! + BOV Line and Gas Canister Recirc/Delete lines not shown) $
^^^$ for everything as a kit^^^
*Stock Exhaust Manifolds w cross over $
INTERCOOLER KIT
*Polished ATR/Conely HUGE Water to Air Intercooler W/ Custom Fill Cap $SOLD
*ATR Upper/Lower w/ dual 4 Electric Fans and Radiator Mount Heat Exchangers $
*Mezier High Flow Billet Cooler Pump 20 gallons per min! $
*AN High Temp Hoses and AN Fittings on it all! $300 worth of lines alone
^^^$ as a complete kit w/o upper intercooler^^^
OTHER POLISHED GOODIES
*Polished Edlebrock Valve Covers $
*Polished Upper Intake Plenum w/ Hardware, IAT Sensor & EGR Delete
*Stock Painted Black Lower Intake Manifold + 12* Hardware $
*Polished RPM 58MM Throttle Body With TPS and I Sensor $
*BNIB Polish Edlebrock Waterpump - $SOLD
*Polished RPM A/C Delete Kit Comes with their belt and the one that I used Hardware and all $
http://i133.photobucket.com/albums/q53/SchnellMotorsports/For Sale/IMG_2111_zps523c742a.jpg
TUNING - AIR/FUEL
Moates Osteritch 2.0, Moates Emulator, ECU w/ All Cables plus IBM Laptop $
Code59 Software and TunerProRT
PLX Wideband 02 Sensor, Omari Tru Color Boost and EGT Gauges $
MSD 6AL Box 5500RPM Plug & Plug and Play Harness + MSD Master Blaster Coil $SOLD
Accel Distributor $
Accel Ceramic 90* Wires w/ heat boots $
RPM Adjustable Fuel Pressure Regulator $
RPM Matched 50lb Injectors $
3 Bar Map $
^^^$ as a kit^^^
OTHERS
*4L60E Transmission, Built(Not sure how, have receipt from previous owner, about 20K on it and smooth shifts, hard launch doesn't use any fluid nor burn it, its as it should be! $
*High Output Black Alternator $
*Optima Red Top Battery $
*Meth Injection with Controller and Pump $
*I might sell the interior which is basically mint, minimal wear on the front seats
Thanks,
Alex
(303) 726-1095
Darin
Re: 4.3L Part out Plus Trans and tuning stuff
I'm curious, do you have pics of the manifold spacer for the t3 turbo?
Feel free to have this comment deleted but if your crank literally snapped in half, I would get the rods and pistons PROFESSIONALLY checked to make sure they are OK. I have personally snapped a crank in half and it took out one rod and two pistons. One of the pistons you couldn't really tell but turned out to have cracked. I just hate to see you sell something to someone that you don't realize is ruined and then they come after you for it.
SchnellGhostTy
Pistons, rods, block will all be inspected before any sale! Pics will come ASAP! Sorry I'm just not able to get to that right now
Sy2211Baldwin
SyTy 4 life
I would like to know more about the transmission , when is the best times to call?
ZavzTy547
Senior Member
Here it is!
I snapped the crankshaft and have decided to put an LS in it instead of rebuilding a 4.3 again so everything 4.3L related must go. All Parts are still on the block on a stand. I am not able to work on it till next weekend really and I have not had a chance to go thru th erecepts to figure out a more solid number for everything. The prices listed are just going off of memory of what everything cost... So I'm sure some things are off base for the actual value. I will do my research as fast as possible and I am sure I am missing things. I will put pics of everything individually as I can take it apart.
I am open to offers for the entire setup but I figure its worth a lot more in parts so here they are. As some things are built to fit with one another and can be separated in kits if you will I will work on prices for multiple items. Do some research though, some of these parts are hard to come by and I am not in a huge hurry to sell anything so please keep the low balling to a minimum Please note these parts are not air conditioner friendly! That was the first thing I removed when I started building this thing.
*JE Forged Aluminum Pistons 8.5:1 $500
*Eagle H Beam Forged Rods $500
*Stock Typhoon Engine Block .030 Over 2 Bolt Mains $400
*L35 Heads 2.02/1.94 - Rebuilt, New Valve Guides, Seats, Push rods, and Lifters + High Rate Dual Wound *Springs(These were in the truck when I bought it) $1000
*Comp 412 Camshaft $150
*Stock Painted Black Lower Intake Manifold $350
*Deepened Oil Pan and Welded AN Oil return Line Fitting $250
*Roller Chain and Chrome Timing Cover $100
*SFI Flex Plate $200
*SFI Balancer $160
^^^$3,100 as a complete kit^^^
TURBO KIT
(It whistles like a supercharger at idle) $2200
*AN Lines except stock oil feedline $250
*T3 Turbo Manifold Spacer w/ external 38MM Wastegate $50
*Tial 38mm Wastegate Blue $200
*Custom Dump in front of the Passenger Well $200
*4" Intake 90* with PCV System AN Connection $50
*AFE Cone Filter $50
*Custom Aluminum Turbo to Intercooler Pipe with Tial 40MM Blow Off Valve & Wastegate Boost Pressure AN Fitting $300
*3" Down Pipe, 2 Vband Clamps and a sleeve at the end to match the rest of the exhaust $550
*PCV System - AN lines to Moroso Oil Separator and then to intake w/ 3 factory check valves, two on pass and one on driver side $200
*Complete Vacuum line setup(As its supposed to be! in complete AN Fittings and un-collapsible Silicone Lines!) $300
^^^$3,750 for everything as a kit^^^
*Stock Exhaust Manifolds w cross over $1000
INTERCOOLER KIT
*Polished ATR/Conely HUGE Water to Air Intercooler W/ Custom Fill Cap $1000
*ATR Lower w/ dual 4 Electric Fans and Radiator Mount Heat Exchangers $750
*Mezier High Flow Billet Cooler Pump 20 gallons per min! $250
^^^$2,000 as a complete kit^^^
*Polished Edlebrock Valve Covers $400
*Polished Upper Intake Plenum $1000
*Polished RPM 58MM Throttle Body $300
*BNIB Polish Edlebrock Waterpump - Have AN Lines for the heater core that can come with $250
*Polished RPM A/C Delete Kit $150
TUNING - AIR/FUEL
Moates Osteritch 2.0, Moates Emulator, ECU w/ All Cables plus IBM Laptop $1000
PLX Wideband 02 Sensor $125
MSD 6AL Box 5500RPM Plug $200
Accel Distributor $250
Accel Ceramic Wires $75
RPM Adjustable Fuel Pressure Regulator $125
RPM Matched 50lb Injectors $500
3 Bar Map $50
Omari Tru Color Boost and EGT Gauges $200
OTHERS
*4L60E Transmission, Built(Not sure how, have receipt from previous owner, about 20K on it and smooth shifts, hard launch doesn't use any fluid nor burn it, its as it should be! $1000
*High Output Black Alternator $250
*Optima Red Top Battery $175
*Meth Injection with Controller and Pump $200
Thanks,
Alex
(303) 726-1095
Do you have pics of the *3" Down Pipe and the T3 Turbo Manifold Spacer w/wastegate installed on the truck?
Tks
Z
SchnellGhostTy
Updated with photo's and what each is available for, again I would like to try and keep everything in each kit to make sure everything is utilized. Hence the discounted prices on the packages versus piece by piece! Feel free to shoot me a pm, text or call! Thanks
90pgt
little off topic but how much power was this setup making?
nice parts GLWS
tunerpike
I am interested in your ATR Upper, but not at that price... Typically they go for around $450.00 used, new from Waller is around $650.00.
Let me know if you would like to make a deal.. Thx
