Aftermarket tie rod setups?
Loeryder
What are the other options besides stock Tie Rods?
Am considering a moog inner outer with an aftermarket adjustment sleeve that is lower profile.
Does anyone know of anything like this?
My current setup is Dustans setup that utilized heim joints.
I am swapping every back to traditional rubber isolated joints
http://www.kgperformance.com/gallery/v/loeryder/My+Ty/MODS/DPT_Coilovers/ for more pics...
I am considering these as well.
Stainless and chromoly rod ends but is 3/8" enough on the tie rod?
It IS 3/8" chromoly though.
http://www.marchperf.com/pg51.html#rods
I believe my last measure put our tie rods around 14.25 +/-
I can check again tomorrow.
Re: Aftermarket tie rod setups?
I have never seen the March performance tie rods, but those look very promising. Bear makes a tie rod call the tracker, but they don't sell a S-Series specific part.
i8av8
what was the verdict on the march tie rods?
4C FED
Absolutum Dominium
I've been looking at the QA1 website. I was thinking of making my own, but using the heim's that have a grease nipple on them.
jpalmer
^Thanks, cause i own the arms now :roll:
Dont worry they are going gloss black
Syclone#892
Not exactly sure but I am betting that those tie rods on marchs website are strictly for belt adjustment and are not meant for steering. As far as I know march makes serp belt systems and thats about it so I would find it odd that they would make steering tie rods.
I remember rumor that baer made tie rods or at least a setup that is for a different vehicle that can be adapted.
Good luck with the search!
i8av8
so the march ends would not be strong enough for everyday use or the occasional launch?
i am very interested in something other than the stock setup. just want to personalize.
jpalmer
I will just make my own with chromolly tube, and hiem joints with f-911 bolts. last setup i used cost me about 150 bucks that included the machining.
Flyin Ryan
hated cuz he drives fords
They make them for mustangs along with a zillion other companies, upr, competition engineering, steeda etc.. there called "bump steer kits" and are used when a car has been lowered allot or when a tubular k member is used with the stock a arms. I don't know if you could adapt them to our trucks never looked at both of them at the same time or year.
warmpancakes
I beg to differ
warmpancakes
Those are bear trackers for the 2wd The inner tie rod end Is from a corvair I think I had to find a shorter inner than the stock one looking back I should have bought a 2wd inner and shortened it
RUSTYNAIL
I have the same set-up on my Sy,I had a local machine shop drill and re-thread the aluminum so I could use a factory inner tie rods. :tup:
