Re: Allison 6 speed
There are both 5 and 6 speed versions of the Allison available. Usually found behind either DMax's or 8.1's. From what I understand, they're beasts. Dimensionally much bigger than a 4L80E, and a fair bit heavier too.
The 6L80E is just now available in the truck platforms, started with the new Tahoe, and should be available now in the new Silverado / Sierra. The 6L80E might be a good swap, if / when somebody comes up with a controller for it.
EDIT: Went and looked for info on the Allison 6 speed. Available starting in '06. Weight is 150kg dry (no fluid) which is about 330 lbs (plus the weight of 13+ quarts of fluid).
'JustDreamin'
