Anyone have any experience with any of these setups?
$449.99 O2Alert System with 1 Wideband Oxygen Sensor
The O2alertis the first data recording system specifically designed to record Air/Fuel Ratios with a warning output! Not only does it record up to 2 Wideband Oxygen sensors but it also records engine RPM and has a programmable Warning output to protect against "lean-out".
Unit is housed in a durable aluminum extrusion with backlit display and is only 4"x3.25"x1.25".
Standard System comes with 1 wideband sensor, engine RPM, Battery Voltage, Warning output, and software. System has options for 1 additonal wideband oxygen sensor, (EGT) thermocouple, 2 analog inputs (pressure, flow, position etc), A/F voltage output.
The Warning output can be used to activate warning light, enable fuel enrichment, shut down NOS or ignition, retard timing, etc.
Recording can be started by preset RPM value or switch.
Adjustable sample rates up to 100 samples per second.
Custom configurations available. Call for info.
Systems are upgradable.
All recorded data can be played back on unit or downloaded and graphed on a PC.
http://www.altronicsinc.com/index.html
Just wondered how this would compare to other options out there in this price range.
