Anyone have 19" rims? They fit?
hatrik8
I was thinking of picking up some 19" rims. Anyone have 19" rims? Tire size are fronts 235/35/19 and rears 275/30/19. Front width is 8.5" 13 offset, rears are 10" 22 offset. I checked the tire size calculator and the difference between the two is 1 revolution per mile. So that is good. I'm just worried about rubbing when turning or rubbing cladding. Also the ride quality with such low profile tires. Right now I have 17" rims and never thought I'd go bigger than 17" or 18", but I might have found a good deal
hatrik8
I figured 19x10 would fit in the rear. Just not sure about 19x8.5 in the front
Sent from my iPhone using Tapatalk
asmo
Sy #2918
Re: Anyone have 19" rims? They fit?
I had 19's on mine last summer 19x8.5 front fit fine with 38 offset, 225/45/19 tires
rear I had 19x9.5 with 255/40/19
hatrik8
Looks great. I decided to not risk buying used 19" rims. I really would prefer 17 or 18
T-Bone
I picked this Ty up a couple months ago and it has 19x10's on all four. The coilovers on all four may have permitted that BUT the tires have rubbed away a small portion of the cladding from the underside inner edge, no doubt from cornering more than starting/stopping. It is not visible unless one is on the ground looking up though.
The trade-off is not worth it to me....I think you wise to opt to stick with 17" or 18".
Icarus-54
Donating Old Member
Saw a sy in Allentown yesterday(#681) had 19's on it.At a distance it looked like it had rims but no tires.
NJSERRANO
I run 18/19's...just keep your tire height under 27" and you should be good. My 345/30/19's are at the limit on a stock height truck.
