autoaddictions
I split My 4l80 case in half!!!! Just kiddin
George ,Im working on a LT1 swap out of a 96 Impalla SS into a Typhoon. Id like to use the Impalla trans and a ECU from a 93/ 94 Camaro (OBD 1) to control engine and trans . My questions are:
#1 The output shaft in the Impalla trans is way long and allthough the typhoon transfercase adpter bolts up no problem, Its sticking out 8 inches past the back. Is it possable to swap the output shafts from the 700r4 to the newer 96 4l60e
#2 If not what do i need two continue to use the Typhoon 700r4 other than hooking the TV cable to the throttle body somehow.
#3 I also have a 9" 3000 stall converter from the 700r4 .Will that work in the 4l60 as well. I know you have the answers. Thanks
Frank
Frank
