Johnny Bravo
Why is my typhoon burning oil like mad? I must go through a quart a tank full of fuel! Plugs look good, new turbo, no oil leaks. I need to do a compression test. I forgot exaclty how to figure out if the oil consumption problem is due to bad rings or valves. I think you can do a compression test, then squirt 10cc's of oil into the cylinder and look for a huge rise in compression to test the rings....vavles...i forgot? leak down test?
Anyway, looking for ideas of how to chase my oil consumption problem,
Thank guyz!:tup:
Thank guyz!:tup:
