Clunk from lowered Ty front end
spyd_98
Hey guys. Just wondering if anyone has experienced this before.I lowered the front end of my Ty to even it out with the back end after I installed the 2" lowering blocks. Cranked the torsion bars until the adjusters were near the bottom, with a few thread remaining. Truck sits nice and level. Cut the bump stops 3/4" or so. The truck drove nice for first few miles with no problems, but after a while, noticed the front end jarring/clunking every time I drive over sharp bumps, especially manhole covers. I looked to check on the bump stops and they have at least 1" clearance before hitting the control arm. A friend of mine had the same problem with a G-body Oldsmobile and found that even though the bump stop was cut, the clearance was not enough for the control arm to have full travel without bottoming out over bumps. And because the bump stop was cut where the ' V ' part was taken out completely, the impact of the control arm hitting the cut bump stop was causing a loud clunking noise. I think he tried the Prothane round lowered bump stops, but had the same problem. He figured that the ' V ' part of the bump stop was at least absorbing most of the impact, so he installed a new stock bump stop, uncut, and the noise and jarring was gone. But because the bump stop was now almost sitting on the control arm, the ride is bouncy, but no noise.
So, to make a long story short, has anyone experienced this dilemma? I read in previous posts that everyone was cutting their bump stops, but haven't heard anyone with the same problem I have. I bought new GM bump stops and I'll be installing them shortly.
Thanks!
blk97ta
Re: Clunk from lowered Ty front end
check your torsion bar mounts ! they make a hellofa clunk when they are bad (sounds like the truck is breaking in half )
spyd_98
Thanks guys. It doesn't sound like a ball joint noise to me. The lower ball joints are pretty new. I'll check the torsion bar mounts, but it just seems like too much of a coincidence that the noise would start right after the front end was lowered and the bump stops cut. Anybody else ever have problems after lowering the front end?
NecroWolf
lost marbles member
mine makes the same sound and it's the torsion bar mount. needs new bushings. other than that a good front end alignment solved all my issues.
