Re: code 12 ???
This code will flash whenever the diagnostic terminal is grounded with the ignition turned On and the engine not running. If additional trouble codes are stored in the ECM then they will appear after this code has flashed 3 times. If this code appears while the engine is running, no reference pulses from the distributor are reaching the ECM.
