computer for datamaster
SeattleSy#1255
Category 5 Conservative
whats a good cheap computer that I can run datamaster on...time to get one AGAIN! :roll:
my old one was a P1 166 64ram and it work good.
any advice?
Rufus
Your previous 166 MHz Pentium with 64 meg is a good minimum platform for Datamaster. More MHz will help you get a higher frame rate and improve playback performance tho. Make sure it has a working serial port and see what is available in your budget!
Rufus
InvisiBill
I have yet to see anyone post that a specific model has problems with DataMaster. It's just a standard Windows program, and thus will run on basically any computer than can run Windows.
I'm using a 120MHz, 32MB laptop I was given. Not the greatest, but it works. If it's a relatively new computer, you'll want to check the serial ports. USB will require some other work, so a DB9 serial port is probably the best way to go. Other than that, just as fast and as much memory as you can afford. When was the last time you used a computer and thought "Gee, this is just too fast. I wish I would've saved the $20 and got the slower one."? =)
Loeryder
Dell Inspiron 5000e PIII 600Mhz 192Mb RAM runs it just fine.
I run the sync at 0 though and it links everytime.
