pinellas50
New Guy
I need one of the circle clip things that holds the cruise control cable on the throttle body. You know the one that is spring loaded so when you just start to get it off with a screw driver, turn for a split second to set down the screw driver, and during this time it launches itself into the engine compartment never to be seen again......
If you have one you could throw in an envelope I could send you some $.
