disc conversion
i'm trying to convert from drum to disc on the sy have gathered everything but the backing plates from a ls1 camaro. parts stores say thay have no way to get them. our junk yards around here dont have them. any sugestions
Sean Krupa
Moderator
Re: disc conversion
Ebay, unless you don't want e-brakes...Jim
Could you please be more specific on this? I'm going to be installing the Front LS1's soon and have the Rear Calipers and Brackets. I don't want to use the E-brake, so what do I need for them to bolt up without the backing plate?
I PMd Renz about making Rear brackets for the Conversion, but he is very busy. Hopefully he can make them by this winter.
Thanks,
blackty
Re: disc conversion
I bought the backing plates, calipers and brackets from ebay. I believe there is a company that makes the bracket you need without the backing plates, maybe kore3? If your state inspection checks e-brake and you don't have them, you will fail. Whose kit did you get for the fronts? I did front and rear at the same time...Jim
