Do all Ty's have Keyless Entry?
ABOSS
Guys did all of the 92 Ty's come with keyless entry? I did a search and found how to program but i dont know if mine came with it
91blazins10
Re: Do all Ty's have Keyless Entry?
yea they do-
Reprogram the Remote keyless Entry Receivers
The programming procedure per the GM 92 ty Manual:
NOTE: You can only have 2 transmitters learned at a time.
1. Turn ignition switch off
2. Jumper ALDL terminal A (white wire) with terminal G (Purple wire).
Door locks will lock and unlock in approximatley 2 seconds.
(could also be a way to test that you have RKE!)
3. Press "UNLOCK" button on transmitter. Door locks will lock and unlock in approximatley 2 seconds.
The transmitter has now been programed. (alhough technically it is the reciever being reprogrammed.)
4. Disconnect the jumper wire from the ALDL.
ALDL: terminal layout
|F|E|D|C|B|A|
|G|H|J|K|L|M|
Pin A is the top row furthest to the passenger's side...pin G is the bottom row furthest to the Driver's side.
91blazins10
Also make sure the receiver is plugged in
vinnieTy
TY # 1889
I have a question.....mine works fine except for one part. When i use to put the truck in drive it would lock the doors it doesnt do that anymore. Is this a program i need to configure in some way?
SY2767
It is a original Ty remote, very little wear. Shoot me your email and i will send you a couple of pics of it. :tup:
