dual spal ic fan setup
typhoon92
I'm going to install my johnson ic pump. since i'm going to have the heatexchanger out i was thinking of doing this setup. is it worth installing them? can you till a differance running these?
sam
92 ty # 0438
Richme
I put dual 7" puller SPAL fans on the rear of the heatexchanger, and there was a noticeable reduction in IC temps, but I don't remember what they were, it was done in '98.
HTH,
typhoon92
are you still running the 7" dual spal fans? i was also looking thru your mods and your running a ac condenser off of a (88 jimmy) as a ic heatexchanger how is that working?
sam
92 ty #0438
Richme
Yep, still running them, along with the AC heat exchanger, and both are doing fine. I went with the Jimmy AC condenser due to ATR's was way too expensive, plus this is alittle bigger than ATR's.
HTH,
