The 411 is an option. But it will need to see a cam and crank signal. You can do that with a later model factory distributor and a later model reluctor wheel, crank sensor(all 96-2004 vortec 4.3)and a timing cover from a vortec sbc. You will also need to modify the harness for the injectors to work. Basically you have to ukld the injector harness. Then you can use any tuning software that will work on a 411. Some 411's run coil on plug in the ls series motors, so that is a possibility if your interested. The 411 will also run a 4l80e if you go that route. But by the time you aquire all the parts, put it all together, buy the tuning software, and pay somebody to tune it( if you cant so so yourself) it would be more cost efficient kn the long run to puchase the holley dominator set up.
As you can see, it would be quite an undertaking to perform a 411 swap on the syclone. I'm sure it offers more tuning options. My buddy just wants reliability and streetability.The 411 is an option. But it will need to see a cam and crank signal. You can do that with a later model factory distributor and a later model reluctor wheel, crank sensor(all 96-2004 vortec 4.3)and a timing cover from a vortec sbc. You will also need to modify the harness for the injectors to work. Basically you have to ukld the injector harness. Then you can use any tuning software that will work on a 411. Some 411's run coil on plug in the ls series motors, so that is a possibility if your interested. The 411 will also run a 4l80e if you go that route. But by the time you aquire all the parts, put it all together, buy the tuning software, and pay somebody to tune it( if you cant so so yourself) it would be more cost efficient kn the long run to puchase the holley dominator set up.
