Ok this is my take on boost controllers.
I have a Blitz unit, and I love it when it is setup correctly. Rock solid boost control, 4 different settings, the spoolup is controlled in the gain feature. So all in all you can have four different settings, street, strip, slow spoolup, fast spoolup.
No matter what controller you have you will always be messing with it during different weather conditions. If you change anything having to do with the air flow, plan on changing it too. The four feature is nice because you can set it for humid, cold, ect. ect.
Now trying to get it setup right is the hardest part. You can try to have the boost controller learn your turbo/wastegate, but that can lead to a boost spike if the gain is played with too much. The other way to set it up which is the best way, is to use the ratio feature and do lots of testing to find the right setting. By setting a ratio, you can also control the gain more efficiently. The ratio mode is known as the manual mode, the target is known as the automatic mode, but can be inaccurate sometimes.
Now again with the four features you can have it set as a ratio in one setting and then have it set as a target in another.
Like I said it is kinda compicated, but when its working correctly it will give out rock solid boost with instant spoolup.
I have to reprogram mine, because I had the vac. lines reversed. Like I said when it works I love it, when I have to fool with it I get pissed.
Sometimes simpler is gooder.
