Engine build up??
My typhoon has over 150,000 miles on her and i think its gona be time for a rebuild soon. I do know that the typhoon blocks are special but how special?? i have a bunch of low miles 4.3 blocks laying around and i was wondering if i can build a new typhoon engine from one of those??
sean
Re: Engine build up??
nothing special on the block just the main caps and lower compersion. you can use one of the blocks just can't run that much boost. i'm shure someone else will chime in
why is it that i wont be able to run much boost?? all i plan on using is the block, the rest of the bottom end will be built.
