Josh Young
kirk
Got a problem with the Syclone and figured I would tell you guys the symptoms and see what you're thoughts are. First off I got the truck out today and drove it for the first time in about a week and a half. It has been pouring down rain here lately and have not had a chance to drive it. I have cranked it twice between the week and a half and let it idle for 5 minutes each time, both times it cranked fine and idled where it should. The weather finally broke and I went after it this morning, cranked it up, idled real low and went dead 2 or 3 times. On the 4th try she cranked and stayed running, I could smell gas and figured I had loaded the plugs up with all that idling. Well I got it out and drove it about 15 miles, and it done fine, ran strong, idled right, so I thought all was good. About an hour ago I went to take it out again, but now when you give it a good amount of gas it just sputters and pops. The truck runs good as long as you baby it, when the truck was in park it is idling at about 1200- 1500 rpms. When you give it a little gas in park the rpms dosent want to settle back down to the 900 or so rpms it normally idles at. Again after you cut it off and crank it again, it idles at about 1000rpms until you rev it up a little then it wants to idle in the 1500 rpm range. Sorry for rambling on, just thought I would give you guys as much info. on the symptoms as I could. Thanks in advance!
