ES frt swaybar bushing kit...
RedlineRex
currently in the process of rebuilding the front end of my sy. since i have the front sway bar off, i figure i might as well upgrade the sway bar bushings. i got the ES p/n of 3.5186 off sytyauthority. can somebody tell me what this kit consists of? i just called summit and the guy thinks it only comes with the two frame mounted (front) bushings and not the ones on the lower control arm. additionally, does this come with new bolts as well? any info would be greatly appreciated. thanx guys... :lol:
RedlineRex
i emailed PST a few months back and they told me that they do not have a kit for our trucks (i found this a little hard to believe since several other syty'ers seem to be running the kit). so i opted to go with moog ball joints, tie rod ends & torsion bar mounts. i also bought a set of ES control arm bushings. so i figure that i should just swap the sway bar bushing out while everything is apart. if i were to start over again, i would opt for the PST kit (assuming that there is a correct p/n for our application).
ed hess
race or get outta the way
as i racall i used energy suspension for everything, rear springs, body mounts, front suspension. However what arrived for the sway bar wouldnt work...
ed
RedlineRex
hey warmpancakes are you talking about the PST front end kit or the ES sway bar bushing kit when you say all four are included?
Rick Krupa
All you got to do is click on our huge ass banner ad at top when it comes around and you'll find the ES bushings along with photos what is included.
adam92
I have the ES sway bar kit on my Ty,and it comes with the 4 bushings,and the 2 center brackets.I got it from Summit for like $25.Has been working great ever since,and no more squeeky front end :D
RedlineRex
hey rick, i thought it would be too much work to look for the banner so i just clicked on the link in your sig... just placed the order about three minutes ago.
i probably could save a few bucks by ordering from summit or whatever but it would be nice to help out those who takes the time to help me... :p
thanks for the help guys!!!
B
Blake
Guest
3-5186
That's the engergy suspension part number on mine.
Blake
B
Blake
Guest
Rick,
Is that part number I posted match the one you have available? That's the number I used a couple years ago when I bought them. Just wondering if it is still current.
Thanks, Rick!
Blake
For anyone else reading this, the syty part number for the bushing kit IS syty specific. You can't just use the 4x4 part for the sway bar kit itself. The rest are run of the mill 4x4 parts.
