Flywheel tooth count...153 or 168...???
J-Man
Changing my starter noticed my flywheel is pretty hammered.
Needs to be replaced..but without trying to count :roll: ...does anybody know the correct tooth count for the Syclone is it 153 or 168?? I was going to order one from Summit as soon as possible so I can get my Sy back on the road.
Thanks Jason
J-Man
Re: Flywheel tooth count...153 or 168...???
Oh man....now what do I order....I'm guessing 168???
Please back this up....I was just going to order it up,.. now still unsure.
I can take a picture you can count them your self...
J-Man
Alright, I'm going with 168. I've tried to find some other info and found I should be calling it a flexplate not flywheel and it seems that the Syclones have "the larger" flexplate which is the 168 tooth. Now I just have to decide to go with TCI or B&M.
MikeRenz
not stock
and spend the extra couple bucks and get yourself the SFI approved flexplate
GarnetTy1473 said:
TCI = Trash Cans Incorporated or so I have been told by some dumb drag racer that likes to turn left at the end of the track and totally smash a car he doesn't even own!!! Although, unlike my truck, his truck at least he gets to make trips down the track so maybe he's not all that dumb after all.
GarnetTy1473
JS Manufacturing said:
TCI = Trash Cans Incorporated or so I have been told by a very famous & handsome racecar driver. That has a running Sy/Ty that I am jealous of, because my own Ty will never move under it own power.
They might be. We have gone through so many flexplates in our race cars, I don't think there was a brand out there we didn't break. Now using a CSR 24 volts starter system. Now the weak point is the starters, not the flexplate.
jjorgensen52
NHSTE - I'm the only one!
I had a TCI flexplate that had some kind of coating on it give me a ton of trouble when I first put my truck together... kept working itself loose from the crank, made this horrible noise too. Still on the truck, seems to be doing alright now that I stripped that stuff off it
J-Man
well after ordering the TCI, I check back on this thread and hear some bad things about it.
I think it should be fine for my application, its better than stock...however I will possibly take off the coating where it bolts up just to make sure. Good Tip jjorgensen!!!
jwaller
Evil Genius/SyTy Guru
I have used tci for a long time without any problems. If your starter is set right and the flexplate is tight you wont have any problems with it. I believe all theirs are SFI certified.
ed hess
race or get outta the way
I dont think you can even buy a non sfi flexplate from any of the common names.
you can allways check out jw. the ultrabell people.
I think everyone but jw all make 168 units for external balance only.
ed
ed hess
for an internally balanced motor the jw part number is 93000.
J-Man
This TCI I ordered from Summit is a 168 tooth, SFI approved, 0.035 in thicker than stock, and internal engine balanced.
