Anybody had success closing / eliminating that nasty vertical 3/4" gap between the front bumper cladding and the front fender cladding.
How did you do it ?????:roll::roll::roll:
You can close it up a bit by pulling the grille, loosening all the front bumper bolts, and pushing the bumper back as far as you can. But if you want it right tight, you need to grind out all the bumper mounting holes to get things closer. Takes a lot of time a patience.
You just have to play with it!!!(aa that did not sound so good ) just loosen up bolts slightly move bumper and tighten, you'll get it close!! Good luck!
