FS/FT: Built '92 Typhoon #0021 $11k
12sec ss
Selling my Typhoon, just tired and wanting something different.. No rust, about 85k miles. If you have something to trade, talk to me as long as its old and/or LSx based..
For those that are serious, my # is 718-689-2220
Asking price is $11000/obo for the truck the way it sits. Below is the list of modifications:
Built Motor, has less then 3k miles on it since dropped in. Motor alone cost $6700, specs are below.
BigStuff3
Racetronix 255 Pump
Racetronix Pump Harness
RPM Crank Trigger
5% Window Tint / 50% Windshield
H4 Conversion Headlights
6000k HID High/Low Beams
Goodmark 2" Cowl Hood
RPM CoilOver Kit
QA1 Front/Rear Shocks
Belltech Rear Swaybar
LS1 Front Brakes
LS1 Rear Brakes
ZR1 17x9.5 / 17x11 Wheeels
275 Front Tires / 315 Rear Mickey Thompsons
CompuSTAR 2W-AS Alarm /w remote start & pager
Autometer Z Vacuum / Boost Gauge
Autometer Z Fuel Pressure
Innovative DX16 LC-1 Wideband
Eclipse 6620 Double-DIn Radio
RPM Turbonetics 60-1 Kit
RPM 3" Downpipe
RPM 3" Exhaust
Turbonetics Wastegate
Manual Boost Controller
RPM Braided Brake Booster Hose/Check Valve
50LB Injectors/Chip
3Bar Map Sensor
TPIS 58MM Throttle Body
MSD Coil
MDS Billet Distributor
RPM A2A Intercooler
RPM Braided Trans Lines
B&M Trans Cooler
Freddy Brown 700R4 < 1000 miles on it (cost $3000 by itself)
ProTorque 3400 Converter
Walbro 255 Fuel Pump
Adjustable Fuel Pressure Regulator
Engine Tie-Down Kit
Truck right now is tuned for the turbo thats on it and 50lb injectors that it has. It will also come with a 74mm turbo but will need 80lb injectors and a re-tune.
This is the motor in the truck. Motor is built by Sagona Racing Engines in NY.
4.033 Bore
8.75:1 Compression
267 Cu In
RPM Lower intake modified for Vortec Heads
Parts:
Speed Pro Oil Pump
Speed Pro Oil Screen
Cloyes Hex Adjust Timingn Chain #9-3145A
Victor Oil Pan Gasket #0532485
ARP Oil Pump Shaft
BHJ Damper #CHIBS6
SFI Flexplate
Comp Cams Magnum Hyd. Roller Lifters #875-12
Comp Cams Magnum Pushrods #7636
Diamond Piston Kit (Pistons, Upgraded Pins, Pin Fit, Total Seal TNT Pro Select Rings)
Calico Coated Rod Bearings #6B1358P10
Speed Pro H Series Main Bearings 139M010/009
FelPro Rear Seal Kit #BS40520
Angus 1.5 Self Alight roller Rockers #1053C
Ultradyne Hyd Roller Cam
Intake Bolts + Washers
ARP Flexplate Bolts #200-2802
Eagle H Beam Rods
FelPro Race SEt #2702
Machine Work:
Boil Block, R/R All Plugs + Cam Bearings
Tap front oil galleys for plugs
Hone w/ Torque plate
Balance rotating assembly
Brass plugs + cam bearings
Crankshaft work - boil, magnaflux, cut 0.10, chamfer oil holes, polish, nitrade
Cylinder head work:
Vortec Heads
Intake valve size: 2.00
Exhaust valve size: 1.560
Valve springs installed height: 1.750
Valve spring pressure: 155 @ 1.750, 365@.530 lift
Combustion chamber volume: 62cc
Valve springs: Manley 1.437 double #22407
Retainers: Comp 10deg #747
Keepers: Comp 10deg #611
Valve Seals: viton for .560 guide
Valve spring cup: Comp #4782
Intake Valves: Manley race flow #11500
Exhaust valves: Manley race flow #11501
Rocker studs: ARP #100-7201
Valve job: Comp valve job + radius exhaust seat
Mill: Clean up mill .005
Pocket porting: Intake + Exhaust bowls + short turns
Narrow guides: Exhaust
Full porting: Exhaust
Gasket match: Intake to FelPro 1203
Combustion chamber porting: Open up intake + exhaust for larger valve, ope up spring pockets for larger spring, drill + tap intake flange for #1203 gasket
Assemble complete engine, check all clearances, degree camshaft, set ring end gaps, check ptvc, weld oil pump pickup, set pushrod length.
12sec ss
Re: FS/FT: Built '92 Typhoon #0021 $11k
Bigstuff3 is tuned by Matt @ TuneTime Performance in Tom's River, NJ
Heres couple pics, any specific shots let me know i'll take them.
El_Jeffe
Sounds like a great deal. Wish I had the money. Do you have any performance info you can post up like dyno or track times? Thanks
12sec ss
No track #s, I havent taken it to the track with the new motor.. On the mustang dyno it made about 300hp / 400tq at about 12psi, the turbo on there now runs out of steam quick.. spools allmost instantly though.. Original plans were to mount the 74mm and do injectors, but i've been spoiled by my blazer with forged LSx 370/pt88, I know the Typhoon wount be as fast, so i dont have the motivation for it anymore..
cheezy69TnT
my new name is TOM PHOON!
man your killin me, lol wana take 86 my monte and like 7 grand, i need my truck back lol i miss it so much
I love the pic of the big fat tires in the back, it looks mean!
Do you have any pics of the engine and interior?
tydye
Banned
just curious how come you reversed the "typhoon" and "gmc truck" logo on the tailgate?
at first i thought the pic was just reversed but noticed the lic plate is normal lol
nice truck! GLWS
Do you have any engine pics? Does it still have working A/C?
Thank you!
____________
12sec ss
Thank you!
____________
AC is all there, just needs to get charged after the engine swap, it worked before the engine was swapped.. whats your email so i can send more pics to you?
bundie
How long do you have the truck?
i thought i have seen this truck for sale 1 year ago with the same pics.!
12sec ss
I have this truck a few years, it was for sale last year with a blown motor, now its for sale running with a built motor :)
nello
Man are these trucks' value is in toilet or what? That's a steal IMO. Tons of hard work, and cash, in that beauty. I was thinking bout selling my truck too, EFF that noise. I can't think of a single vehicle that can compete with a SYTY's performance for such little money.
My buddy just bought a 2007 BMW X5 (4.8 w/ AWD) for over 50k and even he knows it can't touch my SY's performance (especially since it's been in the shop twice for separate issues). BFD that it has leather and is quiet inside, he shoulda bought your TY.
:bump: Good luck with the sale.
