FS Modded Syclone
typhoon92
Re: FS Modded Syclone
Aww - you don't need a tune. 7 gal of C16 and 30psi and it will run a 10.xx. . . once anyway. Then T-Bone will have to buy what's left. ;)
Seriously though - we're here if you or the new owner want her running the best she can! GLWS!
Thank you for the offer! We will see how things go this spring???
VIPERRACING
I did not make it to the dyno last week,been working 10 to 12 hours a day. With a good tune it should easily be running mid 10's
Yes your set-up WILL run 10's all day long. Just make sure the tune is right & DONT BE AFFRAID to turn up the boost.:tup:
typhoon92
This one has peeked my interest. A few questions. What are you tuning with? How big is the fuel system? What has been done to the suspension to support 10 sec runs. What boost controller is on the truck?
To answer your questions I'm running code 59,currently running walbro fuel pump,with 74lb injectors I bought from you I believe? Suspension is stock with frontend tie down limiters and currently use manual boost controller...
T-Bone
Sam, I am guessing (based on provided information in this thread) you have a mid 11 second set-up with a spot on tune. What's your best track time so far with this truck? Regardless, it is still a fine looking machine :tup:
typhoon92
Up for sale again,both syclone and typhoon have been sitting in the garage for the last 4 years.Time for them to go to a new home
