Fuel Injectors
Inferno
Did search, tough to tell what I need... SOOOOO... Engine's out getting a re-build 30 over not sure on the exact parts #'s going in it but I can get info if needed... it looks like a melted a piston, so I am either going to get my Injectors checked, or just replace then. I work at a bolt on speed shop, so Accel injectors are readilly available to me.. I was looking at 150630 check em at summit.. I seen one other post with them, but no one said whether they good or bad... I also am installing a new turbo when engine goes back in, from RPM their stage 2 factory bolt on....
Re: Fuel Injectors
How are you planning on tuning the truck? If you start using different injectors that everyone else your going to need a custom tune.
Was the melted piston on cylinder 3 or 4? If yes, it very well may not have been the injector.
Inferno
Re: Fuel Injectors
Passenger Rear (#6 ? ) and I have an Apu-1, (the craigs moats thing) never really got into tuning, I was running a copy of ultimate.. hopefully someone after can assist with a tune for me...
Inferno
Re: Fuel Injectors
sooo... about them injectors ?? really want to order something tonight so I can get this engine back in...
Beavis
Still plays with trucks
Re: Fuel Injectors
You want to look for high impedance injectors if useing a stock type of setup. I think our stock injectors are 32# or 36#, so those will flow less.....
