Re: fuel pressure adjustment
No need for the key - you can jump the fuel pump using the grey terminal that hangs loose below the power block on the pass side. Set it to 43 psi and leave it. The AFPR should do the rest. BUT..
In the unlikely event that your chip is set to use those injectors at 60 psi idle, it will affect it. I certainly wouldn't be thinking about getting into boost until you know what you have.
As I explained, 1 psi boost will add to base pressure and without knowing what your chip is, it may go to 15 psi, it may go to 25 psi. Base of 43 + 15 = 58 psi fuel pressure, 43 + 25 = 68 psi. MAX.
The delete pipe is a pipe that people use to replace the catalytic converter to free up the exhaust but it can lead to boost spikes. Also, if it is blocked then it will not run right. That IS a mechanical check you can do without a scan tool, as is checking over the vacuum lines.
You need Datamaster or something to look over the other parameters first.
No problem re: the help. There is a lot of info on here so search freely! :tup:
Oh yeah, congrats! Welcome to the group.
