Greddy Profec problems
92boosted303
1992 Typhoon #1155
My greddy boost controller will not turn I have power on both sides the plug jus will not turn on any ideas.
92boosted303
1992 Typhoon #1155
Re: Greddy Profec problems
Yea I believe so its on the same ground its always been on maybe going to a different power N ground?
MRKING
New Parts for Old Trucks
I know you said it has power , but that was verified by a volt meter ? If yes and it does have both power and ground , then your unit may have gone bad .
92boosted303
1992 Typhoon #1155
After testing with a volt meter it appears there's not near as many volts as needed idk why because its weres its always been. Ima try move the ground and power and hopefully have better luck.
