Ground wire 150 issues
gkrcr882
SyTyless......for now!
After doing some testing, per Syclone manual, I've determined that I have a bad ground on wire 150. This makes sense, since the dash lights dont work, speedometer is slow to move, pwr mirrors and pwr locks dont work, along with foglights. Anyone have any idea where this wire all goes to? My dad tracked it pretty far, but I need to know where it grounds the gauge cluster (where it connects to the cluster, and where it bolts to the truck to ground it). Any input is appreciated!
Also- is there any way to splice into the cluster ground wire and run one straight to the body/firewall?
SY2455
70's Veteran
Re: Ground wire 150 issues
My manual shows that this wire is 1 of two ground that are bolted down on the driver side front engine lift bracket. Do you have a manual with you? PM me and working with the manuals I can help you.
