heat wrap quantity?
ashman
plan on wraping my mainfolds, x-over, and dp with the 2" wide dei/thermo-tec stuff. any idea how much it will take?
summit suggest 100' for SBC and 150' for BBC, but there probably talking about headers, not manifolds.
thanks
Andreas
Re: heat wrap quantity?
I doubt that you gone have a good result with 2" wide on the manifolds just look at the shape.
I did the DP with 1" , trying to find what lenght I bought. Have to come back with that when I find the invoice of thar order.
blk00z28
Forced to by choice
Oh yeah wrapping the dp helps. You can somewhat grab it after you've been out driving around and goofing off a bit with it wrapped.
I wouldnt recomend wrapping the exhaust manifolds. Nore the x-over. It'll be a waste. Just have them coated if your worried about the heat.
BacDoc
I looked for some wrap or tape the other day at AutoZone to no avail. I would like to wrap it as it burnt 2 of the 3 wires on that side.
blk00z28
Forced to by choice
Are you running the stock heat shields? What about wire ties, or looms to keep them together and out of the way? I would just buy the plug boots and slip them over the wires/plug boot. It'll be easier on you in the long run. If your burning through the wires then they arnt tied up correct. And if they are, you have some major heat issues and should look into why your getting that hot rather then a quick fix.
Don't use tape. It may be able to hold the temp's just as well. But it will catch on fire easy if it gets to hot. I've seen it happen in a buddies old GN he had. ;)
jjorgensen52
NHSTE - I'm the only one!
I wrapped my headers partly.... the driver's header plus the crossover used 50' of 1" tape. So, I'd say around 120 - 130 if you were doing it all.
I had problems with superheating the brake / powersteering lines. Going to get them coated eventually
UR50SLO
V6+2=LSXCamaro
I used the wrap on my small block S-10 headers back in the day and it ended up cooking the metal and it cracked all the time after that. It's great at holding in heat but will kill mild steel headers.
Not sure what it's effect on Cast Iron would be? Cast Iron is fairly stable at high temps.. It could would out great for under hood temps.
I wraped my stock down pipe with good results but won't do that with the one I'm going to fabricate out of mild steel... It'll cook it!
~Scott
