Hissing Turbo
NeedaSY
Go Ahead N Go
Turbo is making a hissing sound while in or building boost now a whissle sound what could this be (stock turbo). Boost solenoid??? maybe?
SY2932
Administrator
Re: Hissing Turbo
You have a loose clamp somewhere. Check the ones on the hose going between the turbo and intercooler and the two clamps between the intercooler and throttle body.
NeedaSY
Go Ahead N Go
Re: Hissing Turbo
your right the hose clamp at the IC was loose. Where you at in st louis im in south county 2min away from the mall?
Gnocide
turbo game burt reynolds
Re: Hissing Turbo
a whistle while building boost is normally bent or broke turbo blades- if everything else is tight
- use an inspection mirror to see
