Holiday work-on-my-truck-a-thon
BOBA
Ahh, yes... a holiday weekend, time to get my hands dirty. But before I get started I need a little advice on what to check/how to check, and so forth.
I got a few things to fiddle with. I'm not getting 100% full boost again, only maxing at 10-12psi, was getting all 15 last week.
I really want to check on my cat. How does one examine it? I'm trying to figure out if it's clogged or not. Probably going to try and disconnect the wg, and see if the actuator is the problem... tips on that would be nice, but I have looked through the site and found most of what I need. Also, if all else fails, I may open up the turbo to make sure it doesn't have any damage and that it spins right. Really don't want to mess with that one, but if it needs it, it needs it. Hoping new fuel pump comes in today/tomorrow, would like to get that done as well.
I love long weekends.
Syclone#1992
SyTy.net Moderator
Re: Holiday work-on-my-truck-a-thon
BOBA said:
I really want to check on my cat. How does one examine it? I'm trying to figure out if it's clogged or not. .
Catalytic converter? Whats that :rotf: None of my trucks came with one ;)
blk00z28
Forced to by choice
:woot: I'm 3/4 with my big holiday rush modding. I needed some 50#ers and they are in, just needing to put the IC back on and make sure everything is tight wiht no leaks. I cant wait to get this tuned.
Hu Ryde
What mods do you have? Stock chip? Stock turbo? Do you have any vac leaks? Base timing? Is it knocking when you go 100%? Do you hit full boost then it levels out at that PSI or is that all it's got?
I plan to get out and tool on the truck this weekend too.
Loeryder
Me too!
Time to get it assembled for Nats again.
Just gotta get the transfer case and drive shafts back in.
Then i can piddle away at my never ending "wish I had time to do list".
