hose placement ?
pontiacws699
Hey, Iv got a hose that for the life of me cant figure out were it goes and then an electric hookup that iv got no idea. Once i get those then I think im finally rfeady to fire this b*tch up!!
this one come from the top front of the valve cover
REVEREND HARMON
Party in a box!
Re: hose placement ?
hose goes too------pcv valve on valve cover to crossover tube.....
electric plug goes too ---boost solenoid located on the turbo that has vacuum lines going to it from the turbo and waste-gate........
I gotta ask.....
Why did you route your vac hoses on top of your intake?
pontiacws699
:tup:
I gotta ask.....
Ha, i was waitin for someone to say that. Iv gotta reroute it but I just wanted to basicly mock it up and figure out were all this stuff goes. Im gettin ready to go back out and get it ready. So the hose goes down to the cross over and the plug goes to the on the turbo?:tup:
pontiacws699
ok got the hose now but I cant find the boost seliniod were the plug goes. Iv lookd all over the turbo and cant find it. Iv got 2 vacum lines, 1 on bottom and one on top. The one on the bottom has the psi adjustment on it and the top has a short hose , btw i have no idea were that one goes:roll:
psi adjustment(so iv been told)
short hose up top
underneath through wheel well
STORM TROOPER
from the looks of it you stock boost control has been removed, plug the blue line from that manual valve to the vac/boost plug on the turbo and tuck the elect conection back so it doesnt get chewed up or melted and also from the looks of it tighten up those bolts on your down pipe:tup:
pontiacws699
so the plug is not needed? Are you sayn the two vac line on the top and bottom of the turbo go into into the manual boost control cause iv got a long vac line from behind the intake coming over and plugd into the manual boost valve and the short one from the bottom of the turbo plugged into it as well?
this one
Sorry but im not to savy with these motors:oops:
REVEREND HARMON
Party in a box!
:tup:
V6 Kompressor
Your wastegate actuator should be hooked up too, unless you don't wan't any boost... (look through the wheel well. )
