Thats right side up.. My hydroboost has a real stiff pedal feel too. I think it has to do with the leverage that our brake pedal applies and where the fulcrum point is on the whole mechanism. I've been meaning to check out the brake pedal on my dad's astro van as that also has hydroboost and the pedal is not stiff at all.
I have mine upside down (makes more room),my pedal is also stiffer than a wedding dick,but it works fine.The difference is the pivot on the pedal.My astro it's almost an inch higher.
Jack
Jack
Thank you.
And another questions about brake and hydraboost.
May be i need replace prop valve? For disc/disc brake setup?
Already install full brake setup from Camaro 2000. In future in plan install front setup to rear. On front install Corvette Z06 6 pistons calipers and 14" rotors.
