RedlineRex
Okay guys, I went thru the basic troubleshooting procedures diagnosing why my 1 yr old Jabsco pump isn't powering up. FYI, The pump relay is hotwired.
I check the fuse behind the alternator: 12VDC;Good
I disconnect the 2 pin connector for the pump, check voltage: 12VDC;Good.
So now it seems like the problem is the pump, right? Here's the part that stumped me...
I take the 9.6V battery out of my cordless drill and hook it up to the pump leads... powers up?!?!?!
Now I opt to reconnect the 12V power ... nothing... I check the voltage between the two leads and it doesn't measure any voltage when connected... WTF!?! As soon as I disconnect the pump, I get 12VDC again.
Okay, so I'm not exactly a whiz at electronics ... but why would the pump work when fed 9.6V and not 12V? Could it have something to do with the 9.6V being a floating ground while the 12V is chassis ground? Please help...
If it sounds like the pump took a crap, please let me know... Thanks!!
