RedlineRex
hey all, wrapping up my very lengthy upgrade (6mos) of swapping in a pt63, rpm a2a and new 50# injectors (i work very slow). finally got to fire it up today and it seemed to run fine (on jackstands). i noticed one of the injectors (frontmost on driver's side) was seeping a little gas from the top where the injector meets the rail. for some reason i was having problems getting that upper inj clip lined up properly ... almost as if i may have twisted the fuel rail a bit during install by accident. when looking at the alignment of the rail bung(?) and that specific injector, it looks like they werent straight. should i try to twist it back? should i get a new o-ring also? any advice would help. thanks, paul
