sharkbait
the build list is .....
IBS 4.3
poly motor mounts
custom cam (similar to 422)
flat top forged pistons (2valve reliefs)
zero gap rings
studded heads
studded rods
single roller timing chain
old style vortecs
aluminum water pump
H-beam eagle rods
.10 under stock crank
2.02/1.60 valves
three angle valve job
1.6 crane rockers
msd billet dist/coil
msd 6al-2
fluid damper balancer
stock exhaust manifolds wrapped
stock turbo (just to get it running)current is 74mm PTE/.81ar
internal wg
3inch mandrel DP with unshrouded puck
3inch mandrel exhaust with dynomax superflow (no cat, im a dog lover)
stock TB (just to get it running)
sheetmetal valve covers (little bling)
sheetmetal upper intake (alot of bling)
all braided/AN fittings (yeah im a looser)
-8 feed line
-6 return line
external pump/filter
accufab adjustable FPR
harwood 15 gallon w/sender
ABS delete
line lock
manual steering box
battery mounted under rear of bed
rebuilt 700r4
3K converter
poly tranny mount
10bolt rear
3.73
modded posi (heavy springs etc)
this is the build. im going with code59/PLX/TPRT. the truck currently has 50s with the 74mm wg disconnected and the stock chip/ecm. the truck sounds super mean idling and reving in neutral. its a fresh motor so WG is disconnected for saftey. im getting my ostrich/G1 in on tues...and will be hooking it up just to see whats going on in the truck.
so my question is whos got a similar build that runs well on code59? what injectors are you using? im not interested in doing meth. just 94 octane.im farmiliar with the rule of thumb ...if your target (flywheel) HP was 700hp. 700 / 12 = 58.3 So you'd be over the limit of 50s, but you could run 60s/65s and be good.
thanks in advance guys.
IBS 4.3
poly motor mounts
zero gap rings
studded heads
studded rods
old style vortecs
aluminum water pump
H-beam eagle rods
2.02/1.60 valves
1.6 crane rockers
msd 6al-2
internal wg
-8 feed line
-6 return line
ABS delete
line lock
manual steering box
rebuilt 700r4
3K converter
poly tranny mount
10bolt rear
3.73
