Input needed: Planning a chassis swap for an AWD classic truck
no_ty_yet
It's been ~9 years since I sold my Typhoon, so it's about time I build another AWD project. The body will be a '47-'53 Chevy/GMC truck with original paint and plenty of 'patina'. Interior will be nearly stock. Under the classic body will be a turbocharged Gen III-powered AWD chassis. For either option, I already have an NVG-149 transfer case along with a custom shaft to adapt it to a 4L80E transmission.
As for the chassis donor, I'm debating between a couple of options, and I'd welcome your comments and suggestions as to which one would be best. The goal for the truck is to have an all-weather daily driver that would perform well on the street, the autocross course, or the dragstrip.
Option 1 - 2nd gen S-series 4WD truck, standard cab, long bed
* Benefits:
**** Wheelbase is nearly perfect for the '47-'53 shortbed trucks
**** Track width fits easily within the original fenders, so no body mods are necessary (preserves the original paint/patina)
**** The 1st/2nd-gen S10 chassis swap is well documented and fairly straightforward for these trucks
**** Donor trucks are cheap and plentiful
*Drawbacks:
**** Need to plan for a Gen-III engine swap which isn't the easiest in a 4WD S-series chassis due to oil pan clearance, etc.
**** Even the newest of these trucks has some age and mileage on it, so the suspension bushings, front axle u-joints, etc. are likely to be somewhat worn.
Option 2 - Trailblazer / Envoy 4WD w/5.3 engine
* Benefits:
**** Already has a 5.3L engine, so no engine swap is required
**** Chassis is newer, so hopefully suspension bushings etc. will be less worn, aged, etc.
Drabacks
**** Wheelbase would need to be stretched ~3" for a short wheelbase Envoy or shortened ~13" from a long wheelbase Envoy
**** Track width is too wide for the '47-'53 trucks and would require the fenders to be widened ~3" each, which would mess up part of the original paint
**** The number of 4WD Trailblazers and Envoys that were built with 5.3L (or 6.0L) engines is pretty limited, so the donor would be a bit tougher to find for a decent price.
**** I've seen this swap done once under a '47-'53 Suburban body, but I believe they swapped the entire floorboard and firewall with the chassis, so that's a whole 'nother animal.
Questions:
Which chassis can be most inexpensively modified to handle well on an autocross course? Is either suspension system inherently better or worse?
How does the strength of the axles compare between the two chassis options?
Are limited slip differentials available for both?
Thanks in advance
no_ty_yet
Re: Input needed: Planning a chassis swap for an AWD classic truck
Any other thoughts? I'm curious as to everyone's thoughts on the SyTy/S-series suspension versus the Trailblazer/Envoy with regard to modifying for autocross, etc.
Black Knight
I Glow Therefore I am
From what you have listed I'd do the S-series frame swap, your only two listed draw backs are relatively minute comparatively speaking. If my options were clearance an oil pan and change a few bushings over stretch a frame, I take the first any day.
Questions:
Well both and neither, if your doing the work modifying them is easy, just time consuming, but neither was ever designed with autocross in mind so neither would probably ever be that great compared to a car of equal stature.
My only thoughts on this are the newer one would potentially (not much) be better because it was designed with newer technology.
No clue, but I bet the S-series has a larger aftermarket to support it.
No idea, but I would venture to say yes.
It's never going to handle like a Corvette, so my take would be make it handle as good as possible for as cheap as possible, which I feel is the S-series frame. Of course all this is me talking out my ass, so take it or leave it.
gobabygo
Questions:
X2 very well said.
Jimmy
Banned
Don't know shit aboot the Envoy/whatever frame but you said the other one is almost perfect.
There's your answer.
no_ty_yet
That's been my thought as well, but I thought I might get lucky and run across somebody who's had experience with both vehicles that would have some first-hand info.
I agree, I'm leaning the same direction. I remember back when I was running Formula SAE in '99/'00, GM brought a little sportside S-10 pickup out for display that (if I remember correctly) was running modified ZQ8 sport suspension and 10" slicks all around. From what they said, the engineers were allowed to modify the truck and take it to local autocross competitions and apparently did surprisingly well with it.
