Its Alive!!!!!!!!!!!!!!!!!!!!
silverblaz
IT RUNSSSS
ok finally got my truck started for all the people who dont know its a ty engine in a 86 s10 blazer will get some pics up soon
but i have one major issue at the moment which i could use some information on starts and runs but it idles realllllllly high .. checked all vac leaks no leaks ... dont know if anyone would have any thoughts on this wish i could give you more info still trying to get my scanner to talk to the computer .. having a problem with that so once i get that i can check tps iac and all that fun stuff but any thoughts would be good
SY2932
Administrator
Re: Its Alive!!!!!!!!!!!!!!!!!!!!
GREAT news :cool:! So what was the root of your problems that you posted about? May help someone else out...
mattw
Did you swap the Instrument Panel(under dash) wiring or were you able to use that from the blazer and just plug the sy/ty engine harness into the C100 connector?
-Matt
silverblaz
sorry keep forgetting to bring my camera to the shop will have them tonight hopefully if not tomorrow i dont know if i can post them though
and the dlc connection was just a bad wire some where in the harness and hte starter well iguess the ty has another plug that goes to the neutral safety not like a normal s10 so i found the wires i have to move them around but i found them in some black 8 pin connector
SY2455
70's Veteran
Go to http://photobucket.com/
1. Join.
2. Then upload your pictures
3. Copy the IMG CODE and paste here.
4. It will look like this.
silverblaz
thanks will do
i will take some pics tonight when i go down to the shop and post them up sometime tonight ...
mind the fact its in the shop so i don't know how good of a shots i can get i have some i will post from before of the body and air ride dropped and all and all the interior
let me know what you guys think once i post everything
kessler
imageshack.us Can upload and post pics for free and no Account
silverblaz
ok finally have some pics i am trying to put them on using photobucket so if it doesnt work sorry in advance
ok so first off i am still working on it so there is still a bunch of things to do so yes i know things are missing and please mind the mess all the wires need to be cleaned up as well as my dash put back together let me knwo what you think so far obviously there will be more pics to come thanks for everyone that i was able to buy parts off of you were a great help
This is a pic from last winter just thought you should see what it looks like first
silverblaz
they are out of a 95 safari van and its in KM not MPH where is says 160 so dont get confused on that so it only goes to 100 MPH
and thanks glad i got some pics up
Xtrempickup
All turbo All the time
looks really nice, i see a lot of potential with that one. any specs on what you got in there?
silverblaz
Specs
Block/heads 1995 4.3 CPI block and heads 50 000 km on engine
ported lower intake
55 lbs injectors
factory ECM ultimate radar style
turbonetics evolution wastegate
turbonetics manual boost controller
Innovative LC1 with gauge
MSD 6AL
3 inch downpipe
Exhaust wraped crossover and downpipe
LT1 throttle body with air foil
Custom AIR to AIR Intercooler Yonoka Motorsports intercooler 22x9x3"
Afco V8 S10 rad
flexalite 220 dual 10 inch fans
Trans 4L60E 2400 TCI stall
Exhaust cut out
if i left anything else out i will add it later but that should give you an idea of where i am at right now basicly just have to put the fans in clean up wiring and do the exhaust system and put my interior back together
SY2932
Administrator
WOW ! That looks GREAT :cool:! Usually, I'm not a fan of "transplants" since recipient vehicle is usually a POS and the owner got smoking deal on a wrecked truck. That is one of the cleanest ones that I have seen to date. Keep up the good work
silverblaz
Thanks for the comment means alot i have been on this forum for a long time doing my research and i when i do things i like to do them to the best of my ability i will post some of my other vehicles i think you guys will like mine and my dads truck i will post some pics
mattw
Your truck looks damn nice.. You should run a 2nd DRAC and recalibrate it to use that KM numbers as MPH numbers..
-Matt
Luke
Fish sticks SUCK !!!
I like that wastegate setup, did you remove the factory plug on ther turbo and go from there??
silverblaz
nope actually made a pipe come off the crossover up to the side of the d/p i talked to alot of people before i did this and everyone said it should have no negative effect on boost control so i went with it
and as i posted before here is mine and my dads street rod its a 1937 ford pickup and yes we did all the work ourselves if you want more pics i can post them only thing we didnt personaly do was paint it but let me know what you think
