Just. Stopped. Running. ??
RAR1TY
So I put the RPM cat-back exhaust kit on today. After a little time finagling it, got it right and sound. Put truck outside and let idle for 15 mins. Put it in reverse, stalls, won't start up again. Turning over just fine. Anyone have a clue here/had this happen? Totally stumped. And I'm not plugging it in tonight, I'll do it tommorrow.... Thanks.
Damian
Re: Just. Stopped. Running. ??
When you turn the key to the on position, does the CEL come on at all?
Captain Morgan
Moderated User
First thing I would check is fuel pressure (even if you hear the pump turn on, also watch for leakdown).
If the fuel side of things checks out, then I would check for spark. If no spark, I'd probably blame the ICM first, but could be the coil too.
Of course checking for codes will help too :tup:
If you have fuel and spark and still no starting, get a can of gas and some matches :D
RAR1TY
Yes the CEL light is in when key turned. Which didn't happen previously. But this truck has run perfect since day 5 (had to tune it up), never an issue. Now I put an exhaust on it and .... ? Just weird. Plugging in tommorow.
fivetodrive
CRISPY
I think it is more like post #11 :p
Sorry I have never had this happen. Gotta check the codes...
