Kb 911 3000 info
Gnocide
turbo game burt reynolds
Re: Kb 911 3000 info
Back on 2005 I bought this converter from rpm, without knowing anything, anybody can give some info of it? Are they any good? Still worth anything? Thanks in advance
i have the KB 3000 stall 11 inch convertor.the p/n is in the KB catalog.
its not a 9/11 convertor like the billet one from tcs.
you have to look twice at the size vs a stock one to even realize its smaller by an inch.
great t/c-all steel no billet, great street manners spools a 60-1 turbo like no other.
can use it with stock heads and cam as well.
i get 22psi on the street with 20 psi launches easy.
would highly recommend again.
QWERTYphoon
Motley Driver Award 2009
ya x2 great stall!
Gnocide
yes you can use it on a stock motor/heads/ cam
its designed for a bigger turbo to spool than stock.
your gas mileage will hardly be noticeable at all
15-18 mpg
