Looking for pistons and cam
Aforehand
I need a set of pistons and a cam. I'm rebuilding a typhoon engine tying to keep it as close to stock as possible.
graham1524
Well-known member
All the part you need will be on Summit comp 412, 415, 422 cam, and whatever off the shelf pistons can fit the 4.3, they have a search feature that you can select based on rod length, compression info etc to find what you need
