Map Sensors
MAK
I bought a map sensor recently for my Ty. It was supposed to be a 3 bar. I also recently installed a 20g turbo and had Eric do up a Velosyty chip for me (set for 3 bar). When I started it up yesterday it idled great but would barely get up to 40 mph. I limped it home, took out the Velosyty chip and reinstalled the stocker and the Ty ran great.
This is the confusing part: if the map sensor I bought was a 3 bar, wouldn't the Ty run poorly with the 3 bar and stock chip?
I am doubting it actually is a 3 bar. This would certainly explain why it ran rough with the Velosyty chip.
If they did, in fact, send me a 2 bar, does anyone have a good 3 bar they could get to me quickly? I am dying to get this thing running to its' full potential.
Thanks.
Throws
Re: Map Sensors
Thanks.
I've got a 20G and the VeloSyty chip... you're in for a treat! :tup:
-P
MAK
Re: Map Sensors
The one I bought has 9576-E 8 and PBT-GF30 stamped on it. This was to be the 3 bar.
I might get laughed at for this next question but I need to know and I can't find the answer:
There seems to be 2 identical or very similar map sensors on our trucks - one on the firewall (boost gauge line connected) and another to the right of the block (vacuum line connected). Which one needs to be changed to the 3 bar and what exactly does each one control? There it is, laugh away......:oops:
Chest Rockwell
Re: Map Sensors
Got time to take a pic? Could you be mistaking the EGR solenoid for another MAP sensor? They're located on the same bracket.
MAK
Re: Map Sensors
I would have to get the picture tomorrow. FWIW, the sensor I changed is on the firewall (velcro) and it has a line attached to the nipple for the boost gauge. It is a map sensor, for sure. There just appeared to be 2.
MAK
Re: Map Sensors
The map sensor that needs to be changed is right next to the intake manifold
On the bracket? Wow....how did I miss that one......:banghead:
So any idea what this other sensor with the hard line attached is? It is to the rear of the upper intercooler. Mine is attched to the firewall by velcro but I assume it was somewhere else at some point.
I am guessing both were 2 bar sensors from the factory? I hope so.
Thanks for the help.
MAK
Re: Map Sensors
a simple search came up with this thread.
http://www.syty.net/forums/showthread.php?t=87320&highlight=bar+map+sensor
we only have 1 map sensor on our trucks, the other thing you are currently describing is not a map sensor.
If you are wondering what the other item would be, a vac line diagram is helpful.
http://www.syty.net/forums/showthread.php?t=3045&highlight=vacuum+line+diagram
I saw the first thread before. Not much use because the one I replaced on the firewall was definitely the same shape and plug type as a map sensor (whether it functioned as a map sensor or not) and I no longer have it to reference the numbers.
The second thread would have been very useful but I did not see it before. Now the great mystery...what the hell did I replace? Anyone? It is not part of the vacuum system, therefore, it is not on the diagram. Thanks for the link.
MAK
Re: Map Sensors
To clarify, the part I changed out is identical to the map sensor next to the egr solenoid and intake. It has the same plug, nipple, shape....everything, although I can not confirm the part number. It does have a hard line running to the nipple from somewhere behind or under the intake/upper intercooler - I will trace it in the morning. Does anyone have an idea what this part is for and what it is?
DaveP
Re: Map Sensors
Our trucks only have one MAP sensor as-produced. The one on the LR of the engine on the bracket with the ignition coil. However, I have a thought:
What if a previous owner installed a 3bar sensor for the engine management system? The stock sensor also provides the signal to the instrument cluster for the factory boost gauge. With a 3bar sensor, the "zero" point moves down to about 7.5" vacuum reading. Perhaps this annoyed the previous owner enough that he installed the original 2bar and wired it to just the stock gauge to re-establish some semblance of accuracy.
And now you have two MAP sensors. One for the engine, one for the boost gauge.
MAK
Re: Map Sensors
Holy cow, Dave...you might be onto something. I sure hope you are right. I am so confused as to what that sensor was doing over there on the firewall. It has an OEM style plug running to it so I figured it was a factory part. So now that I have a bigger turbo and the Velosyty chip (set for 3 bar), if your idea is correct, won't I need (2) 3 bar sensors?
DaveP
Re: Map Sensors
The gauge is calibrated for a 2bar. So if you want zero on the gauge to be zero, you need a 2bar powering the gauge. You can also do "mental math" if the gauge is powered by a 3bar. In this case, zero is about 1/3 into the vacuum area. And full scale boost is 29.4psi.
But the cluster gauge is not very accurate. I'm not sure it's worth the effort to try to calibrate and retain. I'm not sure I've ever seen discussion regarding a separate 2bar for the dash gauge when changing engine management to a 3bar sensor. Kind of 'new' thinking.
Trace the wires. See what it's for, and let us know.
MAK
Re: Map Sensors
Will do, Dave. Thanks a million. I am guessing the map sensor for the engine is the only one that needs to be a 3 bar. So, from what you are saying, if the other sensor is just for the boost gauge and is calibrated for a 2 bar sensor, it will need to remain a 2 bar sensor to be accurate? I am fine with that....no need to change it. I will trace the wires and hard line in the morning and post back.
Leave it to my damn luck to run across some crazy thing hardly anyone has heard of. And I am sure everyone on here thought I was crazy for saying I had 2 sensors......:rotf:
Wait....confused again.
MAK
Re: Map Sensors
Dave - I got my gauges mixed up. The cluster gauge is calibrated to a 2 bar, the pillar gauge also had a 2 bar. If I change the engine sensor to 3 bar it will cause the cluster gauge to be evn more inaccurate - I get that part. What should I run for the pillar gauge sensor? Since it had the 2 bar to begin with, should I leave it with a 2 bar or go with a 3 bar to show the higher boost levels? Is the pillar gauge affected by this?
DaveP
Re: Map Sensors
Normally, it's not. The overwhelming majority of pillar boost gauges are mechanical. They have a tube to them connected directly to the upper manifold. They are not electrical, so are not influenced by changes in MAP sensors.
If on the very odd chance the pillar gauge is electrical, it could well use the second "mystery" MAP sensor. But I doubt it. You're going to have to sleuth it out. Follow wires and chit, and school yourself as to what you've got.
You'll get it.
MAK
Re: Map Sensors
Thanks, Dave. I am almost certain the mystery map is for the pillar gauge due to the hard plastic line attached to it. I will take a good look at it tomorrow. I need bed now. I have been up WAY to long to be thinkng this damn hard. Thanks for the help.
Syclone22
Re: Map Sensors
Well not all pillar boost gauges all mechanical
Autometer has a electric boost gauges that uses
a map sensor for pressure signal maybe the sensor
you have on the firewall was for this type of unit !!! :tup:
