so I installed new cross drilled rotors and new pads and a little while later my dash lights came on (brake, abs).
My impression is if you compress the caliper and dont open up the bleeder valve to release the preasure it could damage the master cylinder. is this true? If this is the case, is it safe to assume that this is the problem? and i can go ahead and replace the master cylinder?
And then if i do that would there be an advantage to replacing it with one out of a comaro? which camaro? year, model
