need small coolant overflow bottle
vinnieTy
TY # 1889
I installed a kenne bell intake and i need to relocate the coolant overflow. What can i use? Is there one that will fit in the stock air filter location. The original one is to wide.
vinnieTy
TY # 1889
Re: need small coolant overflow bottle
This is what Kenne Bell put in with the intake kit minus the funny looking box. The only change that I made to it was a screw on cap instead of the mickey mouse red one.
http://shop.oreillyauto.com/productdetail.aspx?MfrCode=IDN&MfrPartNumber=BVR4&CategoryCode=3052
The same kit at Auto Zone is made by Quest Part # 511 for $10.99
Sy2455 thanks as well for the help but i have one more question......does it have two seperate locations to connect the overflow for the rad and one for the intercooler or do you make something up and combine both of the hoses.
SY2455
70's Veteran
In the KB kits they put a tee in so you could tie the 2 together. I do not recommend doing this because it never worked right. If you have your stock tank I would use the fitting from it or get a new fitting from the hardware store and locate the intercooler fitting 1" above the other. The tank was to be mounted where the stock air filter was. Hope this helps.
vinnieTy
TY # 1889
How can i take off the fitting from the original and use it on the new tank i buy? Is there some kind of technic to get a fitting on the new tank without having it leak down the line. We are talking about a plastic tank so if i drill a hole and add the fitting im assuming this fitting would need to have some kind of rubber washers so it wont leak....is this correct. Wonder why if i just tee it why wont it work right?
wheels
The stock overflow has a fitting for the i/c that you can unscrew. It has threads, and a nut to keep it tight. PAS drilled standard s-10 overflows for the extra I/C hole.
vinnieTy
TY # 1889
Understood...thanks...Just not at home to look at it.
SY2455
70's Veteran
Thank You Ryan for helping out here as I was away for awhile.
vinnieTy
TY # 1889
Thanks to you and Ryan. I appreciate all the help. I will keep you posted once i receive the overflow tank. I went ahead and bought it from the link you sent. :tup::tup:
vinnieTy
TY # 1889
Just wanted to do a follow up to this thread. Thanks to all the tank was a success. I ordered the one SY2455 stated with the link. I also was able to take the fitting fromt he old tank and transfer it over to the new one an inch above the stock fitting for the radiator. Work out great.
Thanks everyone!! :tup:
SY2455
70's Veteran
You did a nice install. The only thing I found to be a pain in the rear was when changing the oil filter. Because the bottle seem to be in the way, depending on how I feel :rotf::rotf:.
Nitrous
That looks clean! Do you know where I can pick up a new Kenne Bell Intake?
Flyin Ryan
hated cuz he drives fords
try kenne bell.. they seemed to have a bunch of syty old stock a year or so ago but other then that you'd have to pickup used
