Logan
OK, so I am pretty wet behind the ears when it comes to SyTys. I have my Typhoon and got royally screwed on it. I got it home with a horrible knocking sound, power loss and it stumbles after about 2800 rpms. After I checked the compression and all 6 cylinders were at approximately 88 psi I decided my engine is probably trash. I am gonna mothball the original engine and maybe build it back later. I am getting an early 90's block, L35 heads, forged pistons, chrome rings, billet mains or possibly upgrading to 4 bolt and I will get the block, heads and crank cleaned up at the machine shop but what specifically do l need done?
My big question is where do I go from there?
My budget is about 2000 give or take and I want a solid running engine that is reliable and around the 300hp mark. I want to build it to drive, not to race but of course I want to be able to break a few hearts between the stop lights. Right now the mods that are done to my truck are the Ultimate chip with Gauge style display, injectors with a lime/pea green ring? possibly 42lb?, EGR delete, unknown set of headers, no cat, aftermarket manual boost controller underhood and that is all I have identified so far. My question to you guys since you are saltier than I is what should I look for as far as cam set up, any good pointers, things I should change, do or fix? I am wanting to get the parts and guide a shop through the build since I am finishing up my tour in Afghanistan (home in December, Thank God!). Any pointers you guys can give me would be greatly appreciated.
