Re: Newb from Michigan
Yep, Washington. Glad there's a few of you guys local! It's a 93 #0806. Black/Argent. I'm still going through it to figure out what mods were done an why nothing works together. I know it has the cat removed, aftermarket wastegate, crappy "boost controller", lowered on the bump stops, non working Shurflo IC pump, cold air intake, relocated battery, leaks, creaks, rattles, etc.
So far I've taken the drop off, alarm off, plugs, cap/rotor, and am ping from there. The base line timing is off I believe, she needs valve seals, and also can't boost over 8-10psi.
