The oil and temp gauges never worked in my Sy, so I recently replacecd the temp sensor and got the gauge working. I then decided to tackle the oil which was a total bitch to get to. I replaced the oil sender at the rear of the block after of course having to use an easy out to remove the brass unit which broke, but that's another story. After starting it the oil gauge stays pegged at the very bottom like it always did. The rest of them work great including the temp, so is there a common problem with these? The original owner had a bogus under dash three pod that always shakes and leaks as well. Is there perhaps a fuse? The wire and plug from what I can see looks intact. The engine is pumping good pressure according to the afteermarket gauge.
Thanks
Craig
Sy1542
Thanks
Craig
Sy1542
