PCV keeps popping out
The Dread Pirate Fisher
On the rear passenger side, I keep finding the PCV popped out, still connected to the hose but out of its holder. I tried using a bit of silicone to hold it in, no luck.
Was going to next try a small band clamp.
Is this popping out a sign of another issue I need to be vigilant of? Both PCV's are new and the correct 799 one for one of them.
Damian
Re: PCV keeps popping out
Are you still using the original hose for it or are you using a regular straight hose?
Is air pushing out of your vavle covers? you can check it by putting your hand over the oil fill with engine running.
Damian
Is that T plugged up at all? I'm trying to wrap my head around one PCV blowing out instead of that pressure going out the other one or the drivers side breather.
InfinitiTech351
NixATripp
I am having the same problem but i also am having a problem with over/ under boost..maybe it could be related
