Power wire?
Kybol
Where can a guy run a power wire for my amp through my fire wall. I looked quickly but couldnt see anything, so I have mine sittin through the door for now.
5SpdTy
Re: Power wire?
a very easy way is to drill a hole on the passengers side right above the ac stuff on the fire wall. Once you slip the wire through the hole take off the passenger kick panel and there is a flap looking thing, open it and the wire will be right there then just slip it through. run the wire put the kick back and u'll never know its there.:tup:
Re: Power wire?
Their is a metal cover on the driverside where a clutch cable would normally go. This can be easily popped out, its just glued in. On my truck all my Tubing/Gauges Wiring/Alky/WB/Fan Wiring goes through their. I don't have room for an amp power, so I drilled a hole in access panel (again just glue in)below my driver seat.
Joey Allen
MUNCHKIN
Re: Power wire?
According to what size wire. 8 gauge can be pulled through at the attenna wire grommet, 4 gauge drill hole at place of choice.
MAITAI1993
DON'T MAKE ME SLAP YOU.
Re: Power wire?
or run it under and come through in back using gromits make sure to get it out of the door as soon as possable hopefully its fused im an Installer at CARTOYS and we had a guy bring in his 88 cutless in with 0 ga running through the door with no fuse :tdown: it almost burned the car to the floor...
Spinall4
Re: Power wire?
0 gauge will carry enough current with no fuse to weld your ****ing door shut. This is nice say you get in an accident, they your truck lights on fire and you can't get out beacuse your door has welded its self shut.
NEVER run any wires through the doors like that, or underneath the truck also. just too much chance of hitting something down there.
MAITAI1993
Re: Power wire?
TUCK IT IM NOT TELLING HIM TO LET IT DRAG ON THE GROUND THINK ABOUT IT YOU HAVE FUEL LINES DOWN THERE...... :2cents: lots of unused space
syclonekid43
Re: Power wire?
i ran mine on the pass side. i drilled a hole under the annt. gromet it comes out riht under the a/c box
