Pressure build-up in valve covers
sleeper
I haven't ask to much on this forum----read archives so far--alot of similar problems--just
don't know were to start.oil in air box,need some info. I'm not to hot on turbos. Thanks
skata
Re: Pressure build-up in valve covers
blow by gasses in the crankcase get routed back into the intake, and then gets burned in combustion along with fresh air.
you may have excessive blow-by.....weak piston rings. but with a turbo, you'll get some excessive blow-by, especially when you drive hard.
