Propshaft Bolts
Lynn D. Brown
Hey Guys,
I got the 10.8 Hex-head bolts for the Propshaft - tough to find. I also got some new stockers (they're cheap) in case I couldn't get a wrench on the big heads on the rear bolts.
I was able to get a wrench on the rears by turning the shaft once and torqued to 52 Ft-#'s. From the manual it seems to be the same Ft-#'s for the Frt & Back, which is a little surprising. Did U guys use washers or Threadlocker (Blue-Medium) or anything ?
Lynn D. Brown
Prop Bolts
Prop Bolts
Did U use the Red, real tight - or the Blue, Medium tight ? I've always been a little afraid of the Red - I FU'ed some Bilstein shock threads one time w it.
MadPSI
Yeah, don't use red unless you're planning on using a torch to get them off... Red LocTite releases at about 400 degrees...
SY2932
Administrator
Medium strength, Loctite 242, the blue stuff is what I sell in my sets. HTH's
Mike Campbell
B
Blake
Guest
Blue. Won't come out unless you want it to. I put it on, let it set up for a minute and then install it. Red....Use a torch or you'll snap the head off the bolt :evil: Not that I've done that 8)
GM has this orange stuff on Torque converter bolts.
I've used blue on them to and never had one back out or vibrate loose.
George
